According to
http://media.gm.com/division/2005_prodinfo/powertrain/specs/05_truck_engine_specs.html#l52
Type: 3.5L I-5 (L52)
Displacement: 3460cc (211 ci)
Compression ratio: 10.0:1
Valve configuration: dual overhead cam (4 valves per cylinder)
Assembly site: Tonawanda, NY
Valve lifters: roller followers with stationary hydraulic lash adjusters
Firing order: 1 - 3 - 5 - 4 - 2
Bore x stroke: 93 x 102 mm
Fuel system: multipoint sequential fuel injection
Horsepower: 220 hp (164 kw) @ 5600 rpm
Torque: 225 lb-ft (305 Nm) @ 2800 rpm
Fuel shut off: 6300 rpm
Emissions controls: evaporative system
close-coupled and underfloor catalytic converters
APPLICATIONS
Chevrolet Colorado (option)
GMC Canyon (option)
MATERIALS
Block: lost foam cast aluminum
Cylinder head: lost foam cast aluminum
Intake manifold: composite
Exhaust manifold: high silicon molybdenum
cast nodular iron
Main bearing caps: forged powder metal
Crankshaft: cast nodular iron
Camshaft: cast nodular iron
Connecting rods: forged powder metal
Unfortunately, I don't know what most of that means...
