Originally Posted by KrisZ
It is still metal on metal contact. The difference is that this new arrangement can essentially have two cones dividing the torque between them. Throughout the majority of the video I kept thinking how they will cope with the friction forces as the contact area is even less than that of a CVT belt and that metal on metal contact, until he mentioned the special fluid. Basically it all rides on this fluid. I can only guess that Nissan will claim this a lifetime fluid as well.
No it not actually. It is s special fluid that transmits the torque. There is no metal to metal contact in a well executed CVT transmission. The "tech" is all in the traction fluid.
Hence my last mention that it all rides on the fluid. Otherwise it's full metal to metal contact, just like with the steel belt CVTs. The moment that fluid overheats and shears down, the transmission is toast in quick order.
NO.
There is *zero* metal to metal contact in CVT's. Period. There is always an oil layer. In toroidal, and in 'belt' (chain) drives.
If actual metal contact occurs, you have a CVT failure. My two subies with CVT, and countless 100's of thousands of others, have never had metal to metal contact.
Yes, the fluid is critical. So are all the other fluids in engines. Cylinder to ring contact? Failure. Cam to lifter contact? Failure. Crank to journal contact? Failure.
If you understand this, your wording cleverly hides that fact. Please be more clear and concise in your replies, so the rest of us have a chance to understand what you mean, instead of what you say.
(And please, god - get my wife to understand this point!!!!)
NO.
