Here's a quick rundown for you on why CVTs aren't usually seen in the high-performance applications:
- Feel: CVTs are super smooth, which is great for cruising but very dull for sports driving. There's no kick or gear shift surge that you get with traditional transmissions, which is a big part of the fun in performance cars. Yes, it tries to emulate shift points, but that makes things even worse, because now you have a delay in every gear shift, in addition to all the other problems that a CVT brings with it.
- Toughness: High-performance cars need a transmission that can handle intense stress and heat from powerful engines. CVTs are more about efficiency and smoothness, so they're not really built for that hardcore use. When's the last time you saw one bolted on to something like a Hellcat engine?
- Driver Control: In a performance car, being able to manually shift gears quickly is key for speed and handling. CVTs are all about automatic ease, which means less direct control for those split-second, high-speed decisions. Emulated shift points don't work here, because you add even more delay.
- Torque Handling: Powerful engines pump out a lot of torque (you know, the force that gets your car moving). CVTs, especially the older ones, can struggle with really high torque levels, making them less ideal for performance beasts.
So, while CVTs are awesome for a light vehicle and saving on gas, they're not the right choice for high performance vehicles. They're awesome in a commuter Honda Civic, but when's the last time you saw one in a pickup truck or high performance sports car? Just my two cents!
