Originally Posted By: SilverFusion2010
I think it's an ignition timing issue. The timing chain could be stretched, due to coolant in the oil for however long the LIM leaked before I got the car.
Bad knock sensor retards timing, so under load when timing needs advance it doesn't. More Rpm needs more timing.
Ignition Module could be out of whack.
Car has 83k miles. Revs fine in park with no load.
If you rev for a few minutes, say 5 min at 2k, the coolant temp does jump up about 15-20 degrees but does not get to the danger zone.
Thoughts? Things I can test?
Don't worry about the timing chain, you would wipe out the bearings before that. As stated, with the scan tool and going for a drive, you can answer all your questions. Diagnose, don't go assuming and spend your money on parts which may not help you.
