2001 Chevy Silverado 1500 base model with 4.3L (all the power of a 4 cylinder with the gas mileage of a 8 cylinder).
I bought the truck from a family friend several years ago. The truck had about 75,000 miles. It had a harsh 1-2 shift. Not a slide bang, just harsh. All other shifts were fine. I replaced the fluid and filter. All my fluid changes were with Dexron VI. The fluid that came out looked ok and nothing unusual in the pan. Nothing really changed with shift feel.
At about 90,00 miles got tired of the harsh shift and replaced the 1-2 accumulator piston with the Sonnax kit. It was not needed because the factory one was fine and not broken. But since I went this far, I changed it anyway and also used the spring Sonnax said to use. 1 spring instead of 2. Shifting was no better or worse. I drove about 100 miles and had fluid on the shelf so drained it out and put new back in. No change. I put in 2 bottles of Lubegard red. Have driven about 200 miles since and not any change. Maybe a little smoother.
I never get a harsh shift at full throttle. It mostly happens at moderate throttle.
I also cleaned the MAF and replaced the TPS.
I suppose I will learn to live with it or go to a professional. I’m just not sure I want to keep putting money in this old truck. It is not my daily driver.
Any thoughts?
Any thoughts?
