Originally Posted By: Gokhan
Also, straight grades take much longer to warm up (to thin to normal operating viscosity), increasing the warmup wear as well.
Nope, lower VI for the same operational viscosity will warm up quicker, as there's more internal shear.
As to proven to reduce wear...that's bearings at the limits of pumpability, which if you aren't experiencing (pumpability issues) with an SAE 30, you aren't getting (excesive bearing wear).
