Originally Posted By: KCJeep
I assume car makers keep trying to get us to like them because they are cheaper to install, because I sure can't think of any other reason.
CVTs give higher City MPGs because they always maintain the engine at its most efficient point (whereas geared transmissions do not). Honda's CVTs are majorly flawed. The belt works okay, but the pulleys are constantly changing size, and that makes them die prematurely (60,000 miles). I chose the manual shift instead.
Prius CVT is better for longevity, but it still has that "rubberband" feel that drivers hate. It also randomly revs-up the engine to charge the battery, so the sound is disconnected from what you're actually doing with your foot.
And Prius has no manual option.
Originally Posted By: jorton
I called a few shops for transmission service quotes. When I told them it's a cvt they no-quoted
That's because the shops use standard manual or automatic fluid, and neither is suitable for a CVT. (I'm hoping you used the right cvt fluid in your car.)
