Originally Posted By: MolaKule
Originally Posted By: SHOZ
I'd still like to know if I'm not grinding gears is that bad for the snycros? Looks like the Amsoil MTL is a half point lower on the cis viscosity scale.
Redline MTL
TYPICAL PROPERTIES
API Service Class GL-4
SAE Viscosity Grade (Motor Oil) 5W30
SAE Viscosity Grade (Gear Oil) 75W80
Vis @ 100°C, cSt 10.4
Vis @ 40°C, cSt 54.1
Viscosity Index 185
Pour Point, °C -50
Pour Point, °F -58
Brookfield Viscosity @ -40°C, Poise 120
Amsoil Synthetic Manual Synchromesh Transmission Fluid
TYPICAL TECHNICAL PROPERTIES
Vis @ 100°C, cSt 9.7
Vis @ 40°C, cSt 48.3
Viscosity Index (ASTM D2270 190
Flash Point, °C (°F) 150°C Min 218 (424)
Pour Point, °C (°F) -46 (-51)
Brookfield Viscosity @ -40°C 39,050
A half-point viscosity difference at 100C makes little difference. However, the 40C point may make a slight difference in cold weather shifting which is why you need to experiment with MTF's close to the speced viscosity range.
I am not sure I understand this question.
Seeing as the fluid will more than likely never see 100C, I am looking more at the 40C spec. Sorry to have singled out the 100C spec.
As far as the grinding the gears question. Does grinding the gears hurt the snycros?
