Originally Posted By: Gokhan
Originally Posted By: Rendezvous
There are plenty of people including myself who actually own these cars and know about the engine that would disagree with you. The clearance to journal ratio best practice rule that factory and racing engine builders have followed for a long time would say different also. Clevite who made the oem bearing for some of these engines recommends the same clearance ratio. The S65 clearance ratio is smaller than this minimum recommended best practice value. The many failed S65 engines that people have had that were inspected by machine shops and engine builders have said most were from too little bearing oil clearance. Most of these engines also had very tight rod side clearance causing damage to the rod's and crankshaft. There are plenty of documented bearing failures out there that you can research and find yourself. Also the bearing clearances you are talking about for the S65 and toyota engine don't prove any point without mention journal diameters. Without that information their clearance specifications don't mean very much.
Well... I certainly believe you that S65 engine is poorly designed, with bad bearing geometry among other things, and this is causing wear issues. However, I don't believe that the issue is oil starvation here. Even if the rod bearings are tight, there is plenty of room there for even the 10W-60 to flow. So, I don't buy the argument that the bearings are too tight and the oil is too thick so that the bearings are being oil-starved. This just can't be. If that was the case, any engine would be toast with any kind of oil because all oils are extremely thick when they are cold.
Too tight bearing could result in mechanical pressure problems though, as the bearing doesn't have enough play and the high pressures generated by the high-horsepower engine could lead to bearing movement beyond the available clearance. I believe that.
However, in this case, a thicker oil would actually help, not hurt. Saying that a thicker oil is actually causing more bearing wear just goes against everything.
Did anyone run German Castrol 0W-30 or 0W-40 in S65 and saw that the bearing problem went away as with Mobil 1 0W-40? Not according to what I could find out there. Perhaps I would believe that the issue is oil viscosity here if you could point to that. The fact that people are reporting successful UOAs in S65 with only M1 0W-40 tells you something.
Most engines will do fine with most oils.
You see the real quality of an oil only in poorly designed engines such as S65.
Once again, read the Chevron Oronite paper (
link) about TBN retention (why TBN retention is
not all that matters). The detergent package (Ca, Mg , or mixed Ca/Mg) is absolutely crucial in determining lead-based bearing wear and it could be like day and night from one detergent to other.
FWIW, Corolla 4A-LC/4A-C bearing diameters are 48 mm and 40 mm for main and rod, respectively. BMW S65 bearing diameters are 60 mm and 52 mm for main and rod, respectively.
Here are all the specs for Corolla 4A-LC/4A-C gasoline and Corolla 1C diesel engines if you are interested:
https://lh4.googleusercontent.com/-iCD-jqG5TDU/ViVJPTg0UrI/AAAAAAAAyHE/IS06_EJwA-w/s0-d/IMAG4778.jpg
https://lh4.googleusercontent.com/-hjyeOQzwQyE/ViVJPW1HgyI/AAAAAAAAyGE/RmWNimSNjRE/s0-d/IMAG4779.jpg
https://lh4.googleusercontent.com/-XJI8ZOtwVr4/ViVJPQAqtYI/AAAAAAAAyG4/_4S4BMseuLs/s0-d/IMAG4780.jpg
https://lh4.googleusercontent.com/-cafGYh7RMFY/ViVJPTITg5I/AAAAAAAAyGY/-fqtrG6trmI/s0-d/IMAG4781.jpg
https://lh4.googleusercontent.com/-7CaltPcVyqA/ViVJPe2VtuI/AAAAAAAAyGQ/LEp6fdaIsN8/s0-d/IMAG4782.jpg
https://lh4.googleusercontent.com/-wY5JJYqFlIo/ViVJPaPq_FI/AAAAAAAAyHA/ipd3-pw1COI/s0-d/IMAG4783.jpg
BMW S65 specs can be found here:
http://www.m3post.com/forums/showthread.php?t=892838
Wow lolz Did you even read the thread you posted from m3post? It is a 142 page thread about bearing issues with these motors. Its okay though I learned a long time ago to not argue with a brick wall. You know everything.
