Originally Posted By: Gokhan
Originally Posted By: edyvw
Your application? Your car can run on olive oil, not M1 0W40.
The same thing can be said about your car and any German make. Do you honestly believe that most API SN oils wouldn't pass the ACEA engine tests?
Regarding my application, we are talking about an engine that was designed for API SF, when ZDDP and detergent contents were virtually unlimited. 2000 - 3000 ppm phosphorus was common back then. On top of that, when you have a small engine, there is more pressure on the parts when you put it under the load. A BMW can go 65 MPH with 10% throttle but mine requires 50% or more. It's not that you are driving your car on high throttle in the leftmost lane of a German autobahn; so, why should there be a need for better oil for your engine than lower-performance engines? My engine experiences more severe driving than yours based on percentage load/throttle opening.
What ACEA engine test? ACEA A3? No, for example M1 5W30 SN that you can buy in Wal Mart cannot pass ACEA A3/B3, VW 502.00, BMW LL-01, and especially MB 229.5.
So you are saying that your hair dryer under the hood is more demanding on oil then BMW N55 engine?
Please continue, because I really enjoy your writing
