Dear JorgeMartins,
Regarding those results I wouldn´t be worried. Almost all values are on the average side, and only the silicon is (and it was already) above expected. Try to see if there´s something wrong with the filter housing/air filter.
I don´t think that, looking at the numbers only, that you have a problem, but and as obvious, a mechanical failure can occur without warning in any engine at any given time, but I will leave that to the psychics.
Regards.
Regards.
