first, I have been using Mobil 1 since my first car... and I have it in everything I own that uses oil (air compressor, lawn mowers, snowblower, ect..)
So I just bought a new 2015 Hyundia Veloster Turbo (TGDI), the owners manual list this for the turbo model..
API Service SM, ILSAC,GF-4,ACEA A5 or above and either 5w-30 or 5w-40
so... I have been using 5w-30 Mobil 1 EP in my other cars, but that doesn't meet the ACEA A5 rating, it shows ACEA A1/B1 but meets the other ratings..
the Regular Mobil 1 says ACEA A1/B1, A5/B5 and meets the other ratings (so looks to me that I would need to use the regular Mobil 1???
also, since it's a turbo I think I would be better with the 5w-40, but they don't offer that....
I do see there is a 0w-40 but the ACEA for that is A3/B3, A3/B4 (and this is were I'm confused, from searching it would seam this is better than A5??? is that true?
but also, this oil doesn't have the ILSAC GF-5 or API SM ratings...
oh, and there is the turbo truck diesel 5w-40, that list the specs as - API CJ-4, CI-4 PLUS, CI-4, CH-4/SM, SL, SJ
ACEA E7 Issue 2
Caterpillar ECF-2,ECF-3
According to ExxonMobil, Mobil 1 Turbo Diesel Truck 5W-40 is of the following quality level:
CG-4
I'm really loosing my mind on this, I only had the car for 1 week, have just over 200miles on it, and plan to do the first change at 1k, but wanted to make sure I get the best oil to put in... guess I'm a little OCD...
ACEA E7 Issue 2
CG-4
