Originally Posted By: MolaKule
If you are under warranty, I would go first with Motorcraft MerconV, and then Supertech Mercon V second.
If not under warranty and since the price is about the same for all fluids, the Supertech Mercon V ahould be more readily available.
Wolf359
+1
If it calls for Mercon V, I'd just use Mercon V and not any type of multi-vehicle or multipurpose fluid. (quote)
+2
I am a big fan of Maxlife ATF, Castrol IMV, Amsoil ATF etc.....but only when the OE fluid is exorbitantly priced which is not the case with Mercon V. With Mercon V so reasonably priced it's hard to justify using a universal fluid.
