2007 Ford Focus PS Fluid MERCON® Multi-Purpose ATF XT-2-QDX
USA
I am currently changing out a PS pump on a 2007 Ford Focus.
Specification calls for "MERCON Multi-Purpose Automatic Transmission Fluid XT-2-QDX". Can MERCON V be used for this?
I found this post (dealing with manual transmission fluids) referencing MERCON and XT-2-QDX and it looks to not be the same :
https://bobistheoilguy.com/forums/t...zda-manual-transmissions.366533/#post-6423210
If that's the case, any recommendations?
I've used Mercon V in many Ford power steering systems that called for Mercon or even Type F.
There's no problem, and I think there's a TSB where Ford says to use Mercon V in power steering systems that called for Mercon.
If you really want to use the obsolete factory-specified fluid, any "Dex/Merc" fluid will be fine.
