- Joined
- Apr 22, 2016
- Messages
- 1,287
So, I have just over 50k miles on the OEM T-case and I plan to change the fluid soon. It appears the OEM Ford transfer case fluid is very expensive and is probably about the same as any generic Dexron Mercon atf. Whats the deal? Options? Thoughts on using some cheap ST Dexron Mercon ATF? I have a couple jugs of Motorcraft LV ATF from a prior Fusion, is that acceptable? Suggestions please.
