Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
Paint impurities on a new car
by Quattro Pete
06/24/18 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
06/24/18 02:41 PM
Do people buy from telemarketers?
by Chris142
06/24/18 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
06/24/18 01:54 PM
Sonoma Raceway
by Warstud
06/24/18 01:51 PM
Zipcode error
by aquariuscsm
06/24/18 01:36 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
111 registered (2015_PSD, 2009Edge, 69Torino, 87sammy, 1nighttrain, 92saturnsl2, 7 invisible), 1470 Guests and 73 Spiders online.
65312 Members
67 Forums
285939 Topics
Page 5 of 6 < 1 2 3 4 5 6 >
#3994616 - 01/30/16 04:48 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
chrisri Offline
Loc: Rijeka, EU
Your report looks good. I heard plenty of bashing for these little is Renaults, but our just made it to a 400k on 20k OCI. All original.
99 FIAT Punto Sporting 16v MST 5w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
#4232588 - 10/24/16 09:28 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
JorgeMartins Offline
Loc: Portugal
Hi there.
Again, i've requested a 4th engine used oil anaisys and I need some help to interpretate it based in the topic domain.
#4232876 - 10/24/16 05:11 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Popsy Offline
Loc: Frogland / Brittany
How's the air filter?
I'd reduce the OCI but that's just me maybe wink These engines have tiny oil filters...
I thought 5W40 was the recommended oil, but Renault kept changing recommendations on these...anyway, I'd try a xW40 next time if you can, it did better on Elf 5W40.
Anyway, lead and copper values are steady.
96 Barchetta, Motul 300V 5W40 | 98 Barchetta, Quartz 9000 energy 5W40
05 Forfour 95, SHU 0W40 (gf's car) | 10 Colt Ralliart, 300V 0W40
#4233934 - 10/26/16 04:53 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Popsy]
Loc: Portugal
Thanks Popsy.
I used to do 10000 km OCI, this time i forgot it.
Renault recommend 5W30, i'm not sure to change it to 5W40.
#4234054 - 10/26/16 08:56 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Popsy Offline
Weren't the results with 5W40 better?
#4251144 - 11/17/16 05:08 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Popsy]
Loc: Portugal
Sorry, i only find it now, the oil type on the report is wrong, it should be Elf Evolution 900 SXR 5W40.
#4251382 - 11/17/16 11:55 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Popsy Offline
Ok, so the oil didn't thicken then. I'll still reduce the OCI, and try another oil maybe?
#4251407 - 11/17/16 12:21 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Popsy]
Loc: Portugal
Can you be more specific about the thicken?
What oil do you recommend?
Thanks.
#4251408 - 11/17/16 12:24 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Popsy Offline
According to the report, the viscosity of the oil was 13cSt @100°C, which is on spot for a grade 40.
Were the oil some 5W30 like I originally thought, then it meant some thickening (due to oxidation, soot contamination or other factors), which is usually a sign of too long an OCI, or oil too hot, etc.
Can you get some Shell Helix Ultra 5W40? Assuming your car doesn't have a DPF (don't remember)
#4260974 - 11/29/16 12:19 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Popsy]
Loc: Portugal
Hi.
Don't have DPF.
#4261598 - 11/30/16 04:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
UltrafanUK Offline
Loc: England
Originally Posted By: JorgeMartins
Hi there.
The Potassium figure is interesting, although if it is from anti freeze the level is not high enough to be an issue at present.
The OCI was too long and resulted in the oil thickening, also the insolubles figures is near the limit, so I would reduce the OCI to 10K.
No real harm done, but 14K does seem too long!
Too thick an oil can slow down oil flow around the top end, so I'm not surprised the Al figure is a tad high.
Edited by UltrafanUK (11/30/16 04:13 AM)
Shell Ultra 0 or 5w40 or Liqui Moly 5w40 plus Ceratec every long OCI.
LM idle flush every 100K km.
#4266973 - 12/05/16 03:31 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: UltrafanUK]
Bobby_x Offline
Loc: Poland
Hi,
all your tested oils have add packs based mainly on Ca, P and Zn
There are some European mid-saps oils having strong dose of Boron, Moly or Magensium, maybe it's worth to try them if your engine goes better.
Elf Solaris FE 5W-30 - holding Renault 0720 approval, lot of Moly, some Boron and less Calcium
Mobil ESP 5w30 - high Boron, some Moly, less Calcium
Petronas Syntium 5000 RN 5W-30 - high Magnesium, less Calcium
based on analysis:
http://www.oil-club.ru/forum/topic/18416-5w-30-svezhie/
I'd stick to at least mid-saps oils not because of FAP, which in your case is missing, but rather to avoid deposits in the engine and turbo
Bobby
07 Yaris 1.3 vvti mix of 5w30 + Alco sp-991 filter
#4268523 - 12/07/16 08:03 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Esmolante Offline
Loc: Galiza
Bom dia, vizinho. smile
What I have heard about catastrophic engine failure in K9K is that some connecting rods' shells (capas de biela, penso que se chaman en português) lack of flap that inmovilize them. So, that shells roll and block the oil leads. Without lubrication, wear rate rockets, shells are destroyed and then the connecting rod, destroying the engine.
What I can't understand is Renault isn't able to determine what engines are affected. Renauld has (or should have) notice of what part has been used in which engine. It would be as easy as composing a list of engines with faulty shells and replace it.
In fact, I don't know even what incarnations of K9K are affected (o meu sogro tem o dci 68CV, andiven a pescudar e penso que ese motor não está afectado). Anyway, I think doing UOAs is an smart idea. As soon as you see copper and/or lead peaks in an analysis, change the shells ASAP. You can do an UOA each 2 OCI's (but I'm not sure how fast shells destroy once the problem appears).
Oil viscosity: 5W30 seems better for your bearing and 5W40 for cams and piston rings. With both, Iron is a little bit high. I recomend you don't go further of 10.000 km with OCIs.
BTW, several K9K have a big problem with fuel pump make by Delphi. Search for steel savings into the fuel filter and reduce interval to 30.000km maximum. Do some research if your car has that awful Delfi pump (Bosch VE doesn't have any problem).
Sugiro unha Super Bock preta como agradecimento. laugh Cheers2
Até logo!
Kia Cee'd 1.6 CRDI
Fiat Ducato 2.3
Mercedes Vito 108D
Kawasaki ZX10R
Suzuki GSXR600
#4268528 - 12/07/16 08:13 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Popsy Offline
Then pick a "thin" 40, like M1 0W40, or Petronas syntium 7000 0W40, or SHU 0/5W40 smile
#4268752 - 12/07/16 12:58 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Jetronic Offline
Loc: down in the park
If you spin a bearing and block the oil passage, failure is a matter of minutes... starts with knocking, but this possibly goes unheard on a diesel, and ends with a rod through the block probably all in the same drive...
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
