Amsoil and light weight oil
by Bullwinkle007
02/22/18 08:38 AM
What type of Dog Breeds do you own?
by pengem
02/22/18 08:30 AM
Calling AR guys - AR 10 Rear Sight options
by stockrex
02/22/18 08:00 AM
Alexa for seniors
by callbay
02/22/18 07:05 AM
229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
78 registered (BAJA_05, 4WD, A_Harman, 2004tdigls, 2015_PSD, Andrei, 6 invisible), 1449 Guests and 101 Spiders online.
64253 Members
65 Forums
278525 Topics
Page 1 of 6 1 2 3 4 5 6 >
#3387699 - 06/03/14 09:35 AM Used oil analisys on Renault Megane II Break 1.5 D
JorgeMartins Offline
Loc: Portugal
Hi there.
I need some help to interpretate the analisys of the used engine oil from my Renault Megane II Break 1.5 Dci from 2007. Diesel engine.
The main reason that i've required this analysis is because this engine in my car and cars from other brands such as Nissan, Dacia and of course Renault came from factory with serious problems in big end bearing shells those parts broke earlier, about 100.000 Km's to 150.000 km's!! In normal conditions as you know this parts live a car life, 400.000 km 's or more. I don't know of wich material this parts are made, can you guys tell me reporting to my oil analysis if there are elements of big end bearing shells in the oil? If those parts are beguning damaged?
Wich material are made the big end bearing shells from Renault Megane engine?
I've requested this analisys to prevent to open the engine and replace the big end bearing shells
I change the oil at 15.000 Km intervals, and the oil i'm using is Castro Edge 5W40.
Many thanks.
Edited by JorgeMartins (06/03/14 09:41 AM)
#3387718 - 06/03/14 09:56 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Donald Offline
Loc: Upstate NY
I would expect lead and copper to indicate a bearing issue. Copper can also be from an oil cooler.
2015 Ford F250 w/Powerstroke
#3387729 - 06/03/14 10:17 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
yvon_la Offline
Loc: quebec canada
ok ,you might want to tell us what type of diesel ,if it is biodiesel (15%)then wear is normal .bio diesel is very hard on engine ,gas with ethanol or other oxygenator is also insanely hard on engine (too clean or whiter then white so engine is literally broken apart by the fuel or gas)if you can find non bio diesel?you ll still face issue if your diesel is clean (non bio)why?because now a day we got ultra low sufur diesel this is also hard on engine ,best would be a 0.5% bio diesel.since I highly doubt it exist,the next best is to add a lubricity additive to clean diesel. about 0.5% should be adequate for diesel
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
#3387734 - 06/03/14 10:26 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Donald Offline
Loc: Upstate NY
I thought the main issue with ULSD was if you had an older mechanical injector pump like the Bosch VP44 on my Cummins? I do add 1 oz TCW3 per gallon of ULSD.
#3387748 - 06/03/14 10:37 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: yvon_la]
Loc: Portugal
yvon_la,
Only diesel on this engine, never used biodiesel.
#3387829 - 06/03/14 12:08 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
dave1251 Offline
Loc: Maricopa, AZ
Ensure your air filter is in good working order and sealed properly. This should help with the silicon wear metals are not elevated based on universal averages but determining engine wear based on UOA's is dubious at best.
don't use.
#3387830 - 06/03/14 12:09 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: dave1251]
Loc: Portugal
hi dave1251,
I've already checked de air filter it's new!!
Thanks.
#3387845 - 06/03/14 12:25 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
shDK Offline
Loc: Denmark
Originally Posted By: JorgeMartins
Hi there.
Many thanks.
I am surprised to hear you are experiencing trouble with the Renault 1.5 dci engine. Here our national motorist association(yep it is it,s actual name) just had an article in there magazine about the trouble with modern diesels.
According to them that engine was one of the best, and will most likely give you many trouble free km. The worst is the VAG 2.0 TDI and the PSA/Ford 1.6 diesel.
But it also sounds to me like you use the wrong oil. Here they require a 5w-30 RN720 oil.
#3387973 - 06/03/14 04:35 PM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Hi shDK,
I don't have any knowledge about other countries but here in Portugal is a very serious problem, so serious that Portuguese Renault and Portuguese Renault dealers recommend changing the 8 big end bearing shells at 100.000 km's or 120.000 km's. And those dealers support all costs if your car did all maintenance there, if not the client has to support it all.
If you check Portugues forums you will see the many sad reports about that. Cars from 60.000 km's to 180.000 km's!!! The engine model is K9K, mine is K9K 732.
Cand you send me the article or the link?
Portuguese Renault recommend Castrol Edge 5W40 for this engine.
Thanks.
#3388351 - 06/04/14 12:42 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: shDK]
r2d3 Offline
Loc: Romania
... Renault Megane II Break 1.5 Dci from 2007. Diesel engine.
... this engine in my car and cars from other brands such as Nissan, Dacia and of course Renault came from factory with serious problems in big end bearing shells those parts broke earlier, about 100.000 Km's to 150.000 km's!!
Haven't heard of that in Romania, where K9K is omnipresent.
I would try a different oil.
Same here.
'07 Renault Laguna 3 1.5L dci M1 0W-40
#3388377 - 06/04/14 03:57 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: r2d3]
Loc: Portugal
Hi.
I'm not doubting about your report, as said I don't have any knowledge about other countries.
This oil (Castrol) and others like ELF 5W40 are oficialy recommende by Portuguese Renault. That is consentaneous.
In the interval between 100.000 Km's and 120.000 km's, Portuguese Renault and his dealers collect an oil sample and send to a laboratorie in France, then passed a few weeks contact the owner to replace the big end bearing shells.
Thanks.
#3389657 - 06/05/14 11:23 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Loc: Portugal
Guys please, any help here:
I don't know of wich material are made the big end bearing shells, can you guys tell me reporting to my oil analysis if there are elements of big end bearing shells in the oil? If those parts are beguning damaged?
What do you realy think in general about the analisys?
#3390280 - 06/06/14 12:22 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: Donald]
r2d3 Offline
Loc: Romania
The answer is above.
In your UOA, Cu and Pb are perfectly fine.
#3390347 - 06/06/14 05:08 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: r2d3]
Loc: Portugal
Ok r2d3
Thanks for your opinion, let's see if there are other's.
Regards.
#3407259 - 06/26/14 05:06 AM Re: Used oil analisys on Renault Megane II Break 1.5 D [Re: JorgeMartins]
Blasar Offline
Loc: Portugal
JorgeMartins,
As already said, besides the values of Fe, Al and Silicon, your UOA seems normal.
Try the OEM air filter, if you are using other brand, and shorten the OCI to see if the numbers go down a bit.
FWIW, I can confirm what was said about the directives being followed by the Portuguese branch of Renault, and I donīt take too serious what the auto magazines try to sell us, but thatīs another issue.
Regards.
Edited by Blasar (06/26/14 05:07 AM)
Excuse my poor English.
