Originally Posted By: mjk
thanks.
I assume your hour estimate has to do with corrosion, etc?
Absolutely, 18 years is a long time. As artificialist said there could be other parts like brake dust shields that are rotten, rust can make life miserable and time consuming.
Having worked on rust belt cars In both the US and Germany for over 40 yrs, i don't know anything else.
I found out years ago that special tools to do jobs like this in the car only work till they are about 5 yrs old after that it gets in heavy presses and smoke wrenches.
I don't mean to sound pessimistic, if it goes easy you lucked out but be prepared to put a little more than quoted for other parts not in the quote like a ball joint, tie rod, dust shield, half shaft boot, etc.
I wish they came out with book times for North and South.
If he cant get a First world inc Korea made bearing go OEM, you really don't want Chinese in there.
