Originally Posted By: MCompact
Originally Posted By: Finklejag
One of the dealers have all their Abarths $2500 off MSRP. The only problem is , they all have Moonroof and Beats. The two things I don't want. The moonroof takes up too much head room, and I don't like moonroofs that open up on top of the roof. Then the Beats sub woofer takes too much of the already tiny hatch space.
I have my eye on a black Abarth equipped exactly the way I want it(Comfort and Convenience Group, 17" wheels, red leather seats, Beats audio). No hole in the roof or navigation. $3100 off MSRP and 0% interest for 36 months. I am very tempted.
Back to the subject. The Mobil 1 0W-40 spec sheet doesn't show it meets Chrysler's MS-10896 spec. It does meet Fiat's 9.55535-N2. (Qualification for lubricants with a very good characteristics for turbocharged engines, Diesel and gasoline, with extended drain. Minimum requirement is ACEA A3/B4-04)
I say go for it.
I e-mailed Mobil asking which Mobil 1 oil(if any) I should use; here is their reply:
The Mobil 1 0W40 would be the recommended product for your application.
FIAT has typical European engine, and therefore, you can use heavier oils! M1 0W40, GC, PU 5W40 will work great in that engine.
