Originally Posted By: AstroTurf
5 to 10 out of spec is still out of spec.
Howdy Warped Rotors.
Originally Posted By: TFB1
If you know your vehicle and impact you can tighten lugs within 5-10ft lb of spec and never use a torque wrench...
I set my gun to #2, and crisscross the sequence, go around twice and call it a day...
Really? Majority of mechanics don't use a torque wrench when they put the tire back. Come to think of it, it is an exception to find somebody using a torque wrench.
Also within 5-10 is within the 10% tolerance. I do not believe that is going to lead to wrapped rotor. If you have a better documented source to prove your point, I am all ears.
