Vehicle:
2006 Scion tC 2.4L 5 speed.
Oil:
Valvoline NextGen 5w30 Conventional.
Oil additives:
None
Make up oil added: One (1) quart was added during the run.
Engine oil capacity:
4.1qts
Oil filter:
TINY Mobil 1 (much smaller then the OEM filter)
Air filter:
Amsoil EA cone air filter
USE: Mostly highway/city @ 70/30. I was redlining and running the car HARD up till the sample / oil change (to get ready for winter (wanted fresh oil in the block)).
The previous oil was VNG in the same grade that i ran for 3,000 miles after using Amsoil during the previous runs. A Mobil 1 oil filter was used during the first VNG run. The same filter was reused a second time during this current run - so the oil filter has 8,000 miles on it. I drained and reinstalled the oil filter AGAIN for another 7k run (for a total of 15,000 miles, which is what the filter is rated for) and then i will gladly trash it after getting my money's worth out of it.
I started using the VNG because i have a TON of it from the FAR deals and wanted to experiment with it. I ran it for 5k to compare to the Amsoil OE that i started with last year. I'm glad to see the VNG holding up well to the abuse that i put it through on a daily basis.
For the money ($0.00) it is definitely a better value then the Amsoil oils i've been using. Right?
Comments are welcomed.
Here's a few pictures of the Magnetic oil drain plug collecting all kinds of stuff...
Code:
OIL Valvoline NextGen 5w30
MILES IN USE 5,020 miles
MILES 102,713
SAMPLE TAKEN 11/03/2012
Make up Oil 1 qt
Universal Average
ALUMINUM 1 3
CHROMIUM 0 1
IRON 13 15
COPPER 1 1
LEAD 1 1
TIN 0 1
MOLYBDENUM 6 99
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 6 68
SILICON 16 19
SODIUM 272 42
CALCIUM 1952 2748
MAGNESIUM 9 51
PHOSPHORUS 774 754
ZINC 937 841
BARIUM 0 0
Values Should Be*
SUS VIS 210ºF 56.7 56-63
cSt @ 212ºF 9.28 9.1-11.3
FLASHPOINT ºF 410 >365
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES 0.3
TBN 2.7 >1.0
TAN 1.7
Oil:
Oil additives:
None
4.1qts
Oil filter:
Air filter:
Code:
MILES 102,713
Make up Oil 1 qt
Universal Average
ALUMINUM 1 3
CHROMIUM 0 1
IRON 13 15
COPPER 1 1
LEAD 1 1
TIN 0 1
MOLYBDENUM 6 99
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 6 68
SILICON 16 19
SODIUM 272 42
CALCIUM 1952 2748
MAGNESIUM 9 51
PHOSPHORUS 774 754
ZINC 937 841
BARIUM 0 0
Values Should Be*
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES 0.3
TBN 2.7 >1.0
TAN 1.7
