Originally Posted By: chubbs1
Why do you think the RL is SO much superior?
Yeah, I'd like to hear that argument as well.
As far as why RL burns off more, it's either something in RL's composition, or maybe just the fact that RL is quite a bit thicker (HT/HS of 4.6 vs 3.6 for PU), which means more heat is generated just pushing the oil around the engine. Have you noticed higher operating oil temps with the RL? Higher temps = more evaporation.
OP, if you insist on running RL, I would use their 5w-30 in this application.
Also, AFAIK, RL doesn't officially meet the VW spec. RL just "recommends" it for this application.
Yes as mentioned RL 5W-40 is a lot heavier than PU; heck it's heavier than most 50wt oils such as M1 15W-50. The higher oil consumption is hard to explain and may be an aberration unrelated to the oil per se.
Anyway, as QP suggested RL 5W-30 would be a better choice although still heavier than PU 5W-40.
If you're really sold on RL I'd suggest a 50/50 blend of their 0W-30 and 0W-40. That will give you a light 0W-40 with more similar viscosity characteristics to PU 5W-40 but with the added benefit of being lighter on start-up plus the high ZDDP and moly RL is known for.
