Wow - you guys are seriously helpful. First forum I've been on that people go out of their way to provide sound advice. Thank you!
Originally Posted By: pcfxer
Why not continue with Amsoil? Amsoil seems to recommend 5W-40 AFL.
I went with Amsoil when having my oil pan replaced. The shop used it and I had always wanted to give it a try. No complaints here - though I really haven't ever had a complaint regarding oil. I'm sure I will after hanging out here enough!
PepBoys carries M1 5w-30 ESP, but you're probably some good 80 miles away from the nearest one.
Thanks for looking into that. Yeah, I was looking for a PepBoys after moving here.. no luck.
Originally Posted By: ourfamo4
Use any oil that meets A3 or VW502 in a 5w40, 5w30, 0w30, or 0w40. Pick a oil that meets these specs while being in your budget and is readily available close to home. GLX is right in saying 504/507 is the current standard, but 502.00 is perfectly fine for your 30v as they are easy on oils. Also stick with a quality German designed oil filter, these engines run a high amount of oil pressure.
Thanks for the good advice and background info.
Originally Posted By: Tornado Red
There are Pep Boys in Mobile, Pensacola, Panama City, and Atlanta. But if our member from Alabama is traveling to one of those cities anyway, it would be worth picking up some of the M1 ESP oil while he's there.
Good call! I'll keep that in mind next time we're out and about.
