MolaKule
Staff member
Quote:
Dave5358: The first conclusion you might reach is that it's not that hard to meet the SN and GF-5 standards. Start with base oil stock and add calcium and magnesium (both necessary for the 'detergent' nature of the oil) and a good dose of phosphorus which comes from ZDDP - an anti-wear additive. If you did nothing else, you should have an API SN and ILSAC GF-5 compliant oil. If a company or its tribologist is not not smart enough to figure it out, they can just look at the PQIA figures - their work is done for them.
That is not how it's done as I have explained in various posts in many different threads.
Quote:
It is no small task but educating the oil consumer on how oils are formulated has been one of my goals here.
Different oil companies do have different formulating philosophies which are highly dependent upon available PI packages and base oils. The final mix, when tested, determines the suitability to meet various specifications. Much R&D and testing from labs to fleets are done to meet specifications.
How would the oil companies have determined their formulations before PQIA came onto the scene?
