i was browsing a few datasheets of oils to see if i could find a good oil to use for my Capri that i can get locally for cheap, i found Repsol Elite Super which apparently has 1150ppm of Zinc, but phosphororus is not mentioned anywhere, does this mean that the zddp could be lower than 1150 due to the possibility of there being less phosphorous? so for example if it has 1150 of zinc and 800 of phos does this mean that the zddp would be rated at 800ppm? since the zinc needs phosphorous to work
