- Joined
- Jul 11, 2014
- Messages
- 4,117
Fundamentally, fluid level cannot be accurately measured if the unit is not level.I've seen in some places that the transmission itself has to to be completely level, but then other places (the ZF document or that video of ZF representatives) where there is no consideration of the levelness of the transmission.
Is this something that others have paid attention to?
Makes sense. I've seen a picture of a green card of some kind saying how important it is, but the ZF procedure doesn't mention it. Is ZF trusting people too much?Fundamentally, fluid level cannot be accurately measured if the unit is not level.
I've done many spill and fills with both the Charger and Durango. @CarbonSteel is spot on with his directions.
Your pan does not have a drain plug?Any chance you’ve used the mityvac to pull fluid out through the full hole?
Was browsing some pan off pictures and I’m not sure if it’s possible.
I have not, but my trans has a drain plug, so no need to.Any chance you’ve used the mityvac to pull fluid out through the full hole?
It’s worth pulling the pan.
Also, I’m somewhat intrigued by this tool:
https://ctatools.com/products/7650
Your pan does not have a drain plug?...........
I would stick with the ZF Lifeguard fluid. I’m personally not fully confident in some of testing being done by additive suppliers; I’ve been burned before, though not for this particular application.It has a drain plug but it’s practically useless because of an exhaust crossover pipe. (PPE even says the exhaust needs to be at least loosened to install their pan) I’m thinking through future changes. I want to change the filter soon and I’m thinking of only keeping Lifeguard 8 in it until about 100,000 miles just in case of any “good will warranty” needs lol
Was planning on having a local guy that I use for stuff I don’t want to do handle the filter because of that exhaust mess (he’s also the only guy who’s given me any level of confidence in changing this pan). But if I could use a Mityvac or something similar to pull fluid out of the fill hole, I would do that myself a time or two to get a higher percentage of fresh fluid.
After 100k, maybe change over to HPL Green. But I’d want to get as much of it to be HPL as possible. So at that point it would be either evacuation or a PPE to make it reasonable. Rod Knock gave me some good tips for switching to the PPE pan.
Was this the first trans fluid and filter change?Had 199,000 miles on the clock.
Agreed 100%. Honestly, it's sad this has to even be said.Don't know about the other questions, but I would never start the engine with the pan off/fluid drained, not even to get that last bit of fluid out. Yea, there will be some lube still on the moving parts, but not enough for my tastes.
Ouch. 200k is a long way for any auto trans to go on the factory fluid.To the best of my knowledge, yes. I am the second owner. I contacted the previous owner and also the dealership that did all the service for the previous owner and it sounded like the trans, t-case, and both axles had been neglected. So I did the service on all of those items myself when I got the Jeep.
People's experiences with these particular ZF pans is needed.
CarbonSteel said his pan has replaceable filters. My friend's 2017 JGC does not.
RockAuto sells a pan which accepts filter replacements.
Are the ones from RockAuto the only ones which feature replaceable filters?
See my ZF pan change and comments here:People's experiences with these particular ZF pans is needed.
My Jeep is the same as CS - but 2020 and it has the Mopar licensed 850RE. The steel pan has no drain plug + filter is separate …People's experiences with these particular ZF pans is needed.
