It's about time to change the transmission fluid in the 2013 Sienna. Did a flush when we bought it (almost 90,000 miles back) and completely exchanged al fluid with the BG Transmission fluid. Been doing a simple drain and fill ever since. Changing the filter doesn't seem to be a standard part of the procedure on these Toyota "sealed" transmissions. But I've watched several videos lately where others have lifted the transmission a few inches off the mount or used an end wrench to access the two bolts that are "inaccessible." So, I'm thinking of giving that a try. At 185,000 miles it seems like it might be a reasonable thing to do. One reason I'm considering it is that I'm noticing a sort of hydraulic whine on cold winter mornings when backing it out of the garage. Seems to clear up once everything warms up. I'm wondering if an old filter may be restricting fluid flow when cold. Any thoughts? Is it worth the effort, especially since it doesn't seem like a common thing to replace the filter on these?
