Propflux01
$100 Site Donor 2026
The oil that is installed on the filter.By what mechanism will the MAF become dirty?
The oil on the aFe Pro Dry S will contaminate the MAF...The oil that is installed on the filter.
For both my Lucerne and Sierra the AcDelco filters are almost identical to the WixACDelco for both my cars, Wix is 2nd choice. I have no idea whether the AC filters are better than Wix but they are always well built, fit well, perform well according to this old study, and $$$ less than Wix.
I would use OEM for the Odyssey but the local Honda dealer is not my friend.
Sorry, my mistake on the dry portion. I was thinking traditional K&N.The oil on the aFe Pro Dry S will contaminate the MAF...
Got it.![]()
That study is ~9 years old now ... but it would be interesting to see a similar study done with today's air filters to see if anything has changed.ACDelco for both my cars, Wix is 2nd choice. I have no idea whether the AC filters are better than Wix but they are always well built, fit well, perform well according to this old study, and $$$ less than Wix.
It would certainly be interesting to see which ones are still good and which ones are now bad. The only remaining issue would be how well it seals in the air box.That study is ~9 years old now ... but it would be interesting to see a similar study done with today's air filters to see if anything has changed.
Many used oil analysis on multiple vehicles with K&N in my stable show SiO2 at normal low numbers...that is more likely a fitment issue you saw or a filter that was damaged or not maintained properly.^^^^This I will give the OP a pro and a con; I've had an aFe Pro Dry S in use for almost 40K miles, blown it out occasionally with >30 psi gentle air...UOA shows very acceptable Si levels. Con: My son had an '04 Impala while in college a few years back. He had a K&N air filter on for awhile and we did UOA; the Silicon ppm came back in the 900+ range. We threw the K&N in the trash and put a stock air filter on and the Si counts dropped to normal. If someone GAVE me a K&N air filter for my car it would go in the trash.![]()
