Good Morning all...long time lurker, first time post. I am in need of educated opinions and obective recommendations. I own a 2001 ACR Neon w/60k miles. Aside from the first couple oil changes, the car has had nothing but synthetic it's entire life. Neons have always had a problem w/piston slap but I think there are problems elsewhere. I did a change 700 miles ago w/mobil 1 5w-40 and super tech filter (I use 0-30 for winter, 5-10w40 for summer). Upon start up, there are the normal (for neons anyway) ticks for a few seconds, but...(theres always a but..2 in my family)..about 10-15 seconds later, I get a tapping for 15-20 seconds or so. It eventually goes away, but the fact that it is there at all concerns me.I also get some valve clatter when revs drop back to idle like when you are in a drive through and drive from the order screen to the window in 1st gear and coast down to a stop. I have read all the praise for auto rx and seafoam and wonder if these could help. I have some mileage left on the extended warranty and have to take it in to get a strut replaced anyway. I love my adjustable struts, but they are prone to leak. Should I try the self fix-it w/the sea foam and the auto rx or just let the dealer handle it. My only reservation on letting the dealer handle it is that they will use the Mopar combustion chamber cleaner and call it fixed when there could be probs. elsewhere (fix the symptom and not the problem).
In lurking about for sometime, I have learned 2 things, well 3 actually. There are strong opinions about, those opinions are well educated and never use Fram oil filters. I am in need of those educated opinions.
Thanks in advance,
Don
Thanks in advance,
Don
