Wyoming geothermal could provide 10 percent of the national electric needs?
This part of the article really kind of gets to the "meat and potatoes" of the issue:
For geothermal power developers looking to invest in Wyoming, a 2022 assessment of underground hot water resources might help point the way.
Produced by Petrolern (now known as Teverra) for the Wyoming Energy Authority, the 2022 report painted a modest picture of the state's immediate geothermal electricity potential.
Emilie Gentry, geothermal lead with Teverra, said the research used existing public data to map the state's geothermal resources.
"What came out of that report was really, kind of a very regional general mapping of the resource and then an understanding from there based on those temperatures at depth, can you produce electricity?" she explained.
The Wyoming-specific study found that the state's geothermal resources are moderate to low temperatures and situated in localized regions throughout the state.
Many of the geothermal resources are below 200 degrees Fahrenheit and not ideal for generating electricity.
"Most of the state is better suited for direct use, meaning using that thermal water for heating,” Gentry explained. “And that can be homes, it can be town main streets, it can be manufacturers that use higher temperatures."
However, the study did identify some promising areas for geothermal electricity generation.
The 2022 study identified 1,284 wells within the state that are above 200degrees bottom-hole temperature that are not plugged and abandoned.
The Powder River Basin, particularly the southeastern portion near Casper, emerged as one of the most promising regions.
The Salt Creek-Meadow Creek area, located about 4 miles north of Casper, shows exceptional geothermal potential with higher heat flow, numerous faults, and documented flowing water wells with temperatures reaching 183°F at the surface.
Southwestern Wyoming around Rock Springs offers substantial opportunities with 863 wells above 200°F — the highest number among all Wyoming basins.
To generate electricity, the higher the temperature the better. A nuclear plant produces "moderate" temperature steam; steam that is cooler than what is used at a fossil plant, which is why they are less efficient in terms of turning those MWth into MWe. A nuclear plant that uses steam generators has a boiler outlet temperature of about 528F, which yields an efficiency of about 31-32%.
So, setting the bar at "above 200F" for a limited cross-section of these wells isn't putting it very high. You need much higher temperatures to make it worthwhile to try and harness it using the Rankine Cycle.
The article mentions the Gysers facility in California, which has a fantastic Wiki:
https://en.wikipedia.org/wiki/The_Geysers
There is currently 1,590MWe of installed capacity at Gysers, covering an area of 29,000 acres (120 square kilometers). None of the units are "large", which the biggest being 119MW. Production is about 6.5TWh.
As of the end of 2024, California had an impressive 2.04GW of installed Geothermal, which produced 6.69TWh or about 2.81% of the state's electricity.
In comparison, California's only operating nuclear plant, Diablo Canyon, at 2.27GW, produced 18.4TWh over the same period, or about 7.72% of the state's electricity and its grounds are probably a couple hundred acres.
So, to me, this sounds a lot like the "Geologic Hydrogen" hype. Yes, these geothermal resources "exist", but are most of them worth exploiting? Probably not. That doesn't mean we shouldn't exploit the ones that ARE worth exploiting however. Geothermal is another tool in the toolbox for displacing FF's in powergen.
The geothermal energy in Wyoming is from the enormous magna chamber of the Yellowstone caldera. A level 5 eruption could reduce our need for geothermal anything. I recommend watching 'Super Volcano' (2005). Impossible to predict if or when.
Yep, let's throw everything then, lay down in fetal position and give it a good panic attack.
I recommend watching the first Transformers too, there was a Nokia phone there that killed someone, and an airbag became claws, and I've been scared of using either ever since 😇
Can, sure. Whether it is cost effective? Probably not.
I remember New Zealand has something similar and they actually cost way more than a fossil fuel thermal power plant because of the corrosion requires regular replacement of stainless steel pipes in high heat environment. Those cost were never recouped when compare to easier to maintained coal and natural gas plants. I'm sure Rockfeller would have done it if it is profitable. Their family grave is right next to it already.
There's scientist...and engineers
Scientists say "could", Engineers have to turn things into cost effective paractical reality.
I'm on a trend now with the idjits claiming 90% lus for sand storage...it moderate temperature, so, in the 20s to 30% efficiency rate...not 90%. The comeback is that "the rest is alll available and usable as heat".
Which is correct, but if that was the case, a coal plant, or GT, or nuke is also 90-95 percent efficient...we just can't use all that low grade heat...could to heat the roads in winter (if needed)...but thousands of miles of pipes means we dont
The Yellowstone caldera is so well vented in so many different places, that there is little chance of a major explosion going off anytime soon (thousands upon thousands of years). You need to build up pressure for a major explosion-venting really interferes with that. That doesn't mean there can't be events, but level 5 or even close to same, is quite unlikely.
And I suspect that setting up geothermal facilities in the area, would only tend to increase the venting.
