No, that's a stupid point. That statement is just another BITOG Chicken Little, parroted, scripted response. T5 is a simple dual-rated HDEO that meets SM. I have a vehicle that was built when SJ was the current spec. Still has the original catalytic converters and "She just loves it" and "She just gobbles it up".
Are you people too lazy to do a little investigating? Or is it just too easy to copy what you read here once, right or wrong?
Mobil 1 10w30 HM (One of the closest PCMO's you'll find to T5)
Phos 1000
Zinc 1100
T5 (Recent UOA from a respected member)
Phos 1059
Zinc 1183
Shell Rotella® T5 Synthetic Blend Heavy Duty Engine Oil combines synthetic blend base oils and advanced additives to deliver excellent protection, even at low temperatures where the enhanced cold-flow properties help protect your engine. Shell Rotella® T5 is formulated and designed to energize the oil's performance and provides fuel economy benefits*, improved low-temperature flow, and delivers an advanced "Low-SAPS" formulation which helps control the blocking or poisoning of exhaust after-treatment devices.
So what is it exactly that the catalytic converters won't like?
SQUAWK! Polly wants another cracker!
Originally Posted By: Doog
Thinking about all of my vehicles and OPE and wondering if 10w30 T5 in 5 gallon buckets or even a 30 gal barrel might be better?
Two 2GR-FEs (5w30) one 2AZ-FE (5w20) and one Honda 1.8L (5w20). Lawnmower, generator, power washer.
I am pretty sure all of these engines will run just fine on a 10w30. Why not just go bulk and buy a 30 gallon drum from a distributor and do away with all of the different flavor nonsense. I change all at 5000 miles anyway.
Thoughts?
Your engine may like diesel oil all the time. But I'll bet your catalytic converter won't like it all the time.
good point
