Originally Posted By: Ama0787
Yes cold pavement alon basically stops the power from getting to the ground right around 65 degrees I lose all hope of traction but I do like to run the car at least a couple times a month so it doesn't sit to much
Thanks for the advise. Do you like the 5w40 for my daily subaru which is also modified around 400awhp
Do you strictly use m1?
Iassume that 33lbs of boost is e85 or higher than pump octane fuel. Am I correct?
TIA,
Anthony
Back in the late 70's and early 80's, we had never heard of E85. However, our lowly race team, with 2.3L turbo Mustang did reside in the paddock next to the F1 teams at the Detroit Grand Prix. We learned about a Toluene blend as a turbo fuel. Today, there is all sorts of urban legend with Toluene, but as a turbo engine developer, we were in the loop and know/knew how to make it work.
I am able to run as much boost as I want, within mechanical limits on a 93 octane and industrial Toluene blend. The more boost, the more Toluene. Heat is also required, as it does not vaporize well.
Yes, 5W-40 is really an ideal viscosity. Many synthetic versions are quite robust.
No, I am not a M1 exclusive guy. I simply find that M1 is commonly available and, with the proper choice, can be made to work as well as much more expensive products. I also use Redline products regularly, BelRay for the bikes, and occasionally Amsoil products.
It really is hard to beat the $25, five quarts M1 and a M1 filter "deal" at Vatozone!
