Originally Posted By: Ama0787
Thanks for advice and links the supra has seen m1 10w30 since new with the most recent oil change going to RP 10w30 I probably shouldn't have switched but I got use t using it in my Subaru maybe I should go back to it do a UOA and then look at going to the M1 15w50 the recent kmart sale @ 4$ a bottle got me around 60 qrts of it so I hope it works.
I have a optima battery that has 800 cca but some how the optima batteries don't seem quite up to snuff at least not when they sit. My DD Subaru has a yellow top that has done we'll but the car is driven everyday but the red top in my supra blows the only positive is auto zone 3 year warranty so I get new batteries a lot I think Im on 4 or 5 now.
Blusubie,
How long have u been on the m1 0w40 that is what I was considering going with on my spec b which has the same basic motor you have.
Any UOA's done with it and is it the only weight you have used dice owning the car or did you just make the change recently?
TIA,
Anthony
60 quarts should last you for a while...
If you are even going with ridiculously short OCI's I can't imagine 60 quarts lasting less than a couple years? How much do you drive this car, anyway?
Who knows: there may just be some "better" NEW-IMPROVED! oils on the market in 2015, or so?
Cheers!
