Originally Posted By: TurboLuver
Originally Posted By: JHZR2
All Im saying is that the MFR of FF has recommended latex paint sprayer type equipment that produces very high pressure. Krown comes out with just air. If FF works in alternate setups, great, but its not what their mfr recommends, FWIW. Just relaying what they told me.
I bought the above pictured sprayer from the leading Fluid Film distributor, that is the recommended application tool and it works at between 60-80psi on common shop air.
I don't know where you get that you need some type of special spray gun, but I use it and I can tell you that it works perfectly with this spray gun from a normal air compressor.
Dan at Fluid Film. Ill paste my email response from him as well as my initial question below:
Hi,
Both products will penetrate quite effectively given time. The main difference between the two are the environments they were manufactured for. Our regular Fluid Film holds up much longer to UV exposure than the Liquid A product, so it is the only product that should be considered in any application where the sun exposure will be an issue. The Liquid A is used more as a "Float Coat" in marine tanks, or as a dipping material for metals before shipping or storage, due to its low viscosity.
Our regular Fluid Film will work better for the majority of applications. In bulk, the easiest way to apply the regular Fluid Film is by airless paint sprayer, with a psi of around 2,000 for best atomization.
Both products are safe on paint, plastic, and oil-resistant synthetic rubbers. The Gel that the Liquid A forms is unique to that product because of its designed use in a marine environment.
What are your desired applications?
Regards,
Dan Wxxxxxx
Technical Sales Manager
Eureka Chemical Company
234 Lawrence Ave.
South San Francisco, CA 94080
www.fluid-film.com
-----Original Message-----
Sent: Wednesday, August 31, 2011 8:04 PM
To:
[email protected]
Subject: Fluid film and Liquid A
Hello,
Can you please help me to understand the difference between fluid film and the liquid A? It seems that the liquid A has a penetrating capability that the standard fluid film does not. Is this due to a different chemical composition, or some other chemical difference?
Would one have a more damaging effect on rubber or plastic? Is one easier to spray?
Is the "gel" that liquid A forms different from the water interaction with standard fluid film?
Will either solve fully cured automotive type paint?
Thanks for your assistance!
