Originally Posted By: Zaedock
If you do in fact, have 0 oil pressure, replace your oil pump. I'm a Jeep guy - have 2.5L and 4.0L rigs, a 4.0L buggy, and work on friends Heeps. In my experience, the average factory pump life is about your mileage. Also, IMO, the factory Jeep upper oiling has never been super. I usually add a high volume pump with either a rebuild or replacement but the stock volume replacement usually cures the Jeep "tick", other noises, and low pressure. Currently building a 4.0L Renix for my kid's Cherokee and will be adding a Melling HV pump.
If memory serves, the standard volume Melling pump you need is an M-81A. For $60 or $70 and a new oil pan gasket (get the Felpro one piece rubber with steel inserts) is worth a try.
Are you serious? That's some pretty awful pump life IMHO for an engine that is so oft touted as "bulletproof"......
From what I have seen, that has been the average. Sure, there are 4.0L's with 300K with untouched internals, but I've seen pumps fail well before 100K (IIRC one around 60K!).
If the pump has been replaced, as you've guessed - you're on borrowed time.
The 20W50 route is an option. If memory serves, Castrol Syntec 20W50 has a 20 something cSt viscosity at 100*C. You could try that.
Craigslist, online crate engines, and your local club forums would be a good way to find a replacement. The swap could be done in less than a day.
