Originally Posted by oil_film_movies
Fram Ultra filters much better. Wix XP has poor filtering efficiency. Thats about the only difference. A big one though.
I also saw the cut up of the Wix Xp and the Fram Ultra, the pleats on the Wix Xp and at the bottom of the filter where the drain back silicone seats seems to be better made vs the Fram Ultra.
Very interested in your response. Thanks.
BTW, how does Fram Ultra filters better than Wix XP.
Originally Posted by Linctex
Either one will get your car to 200,000 miles without any lubrication system failures.
I want my Corvette to last 250k and beyond though, so when the new 22psi bypass Ultra filter comes out in the new year, that's what I'll be running on it from that point on
Define better? What are your expectations? Fram ultra has great efficiency ratings and well made. XP is very well made and has lower efficiency ratings. Either works. I rather have better efficiency. Although either will work.
LOL!!! Any good oil filter, even with a "mere 8-10 psi bypass valve" will get you to 250,000.... if all else is equal.
The difference between a 8 psi bypass valve and a 22 psi bypass valve = zero effect on engine life
