Kohler and Wix alternative- WL10068
Maryland USA
I am looking for alternative filters for the Kohler 52 050 02--S for a marine generator, and the only one I have found is the Wix WL10068 , which seems to be the basic Wix filter. I would prefer a Wix XP, M1, or other high end filter that has better micron rating- the Wix appears to be 99% at 40 micron. Any suggestions ?
I found this on an old post -
Turns out the part number in the Kohler service manual was formatted a bit weird - once I started searching on Kohler part 52-050-02-S (instead of 52 050 02-S as in the manual) then all sorts of alternatives popped up, including the Wix 51348 and the Mobil 1 M1-102a. It turns out I have plenty of the M1-102a so I will probably use that filter.
