Preparing to install some house window film, as a rookie. Wet spray, static cling type; no adhesive. Material is not wide enough to span the width of the pane, so there will have to be two pieces, with a seam in the middle.
1) Better to pre-cut and then apply what needs to be trrimmed, or apply first, then trim in situ, assuming the material is pliable enough, like car tint is done?
2) Suggestions for a cheap, long straight edge guide to prevent uneven cuts?
3) Any other tips?
Ultimately, it doesn't need to be perfect, since it won't be subject to close inspection, but the desire to do a neat job is still there.
3) Any other tips?
