Exactly. Multi-viscosity oils defy the laws of physics. You got it!wait, I thought oil gets heavier as it heats up.
doesn't 5W30 mean 5 weight when it's cold and 30 weight when hot. Isn't 30 higher than 5?![]()
Maybe and maybe not. Everyone has an opinion and the end of the day, you need to do you. I donāt t want people to be scared into believing that xW20 oil is bad for your engine or you will have damage over time. Iāve seen the light when my Accord (which I bought brand new) is about to hit 300,000 miles running 5W20 and my Tundra Is about to hit 200k running 0W20 with heavy towing and I live in South Texas. A lot of great opinions here. I always say careful whose advice you buy, but be patient with those who supply it. You can learn a lot from listening and be able make a decision with more knowledge than you had before. I can say I have learned a lot. Even from these āfellersā.Youāre not making sense Edd...d! Re-read what these fellers are telling you with a critical mind and youāll see the light. BTW, Patās video been savaged here before.
0W20 at room temp is far thicker than 20W50 in a running engine, so, tell me again what the ātolerancesā canāt handle?
Calling other people āmoronsādoesnāt qualify you as a genius...and it certainly doesnāt make you right...
Ok but that 50s 5.2L V8 had like.....200hp (or even less)....
And cars of that era never made it to 100.000kms anyway (due to inferior metalurgy of that time)
Their engines got rebuilt before no matter what oil was in there
Terry Dyson, who lived here 2002-09 and did oil analyses for a living would have taken that apart.
Millions of fleet vehicles make it clear that UOAs are relevant.
Even though I prefer thicker oils and you do not, this comment of yours is one I really respect.Maybe and maybe not. Everyone has an opinion and the end of the day, you need to do you. I donāt t want people to be scared into believing that xW20 oil is bad for your engine or you will have damage over time. Iāve seen the light when my Accord (which I bought brand new) is about to hit 300,000 miles running 5W20 and my Tundra Is about to hit 200k running 0W20 with heavy towing and I live in South Texas. A lot of great opinions here. I always say careful whose advice you buy, but be patient with those who supply it. You can learn a lot from listening and be able make a decision with more knowledge than you had before. I can say I have learned a lot. Even from these āfellersā.
Well, in truth the question proper should be rephrased because the correct answer is yes and no depending on a host of conditions and qualifiers unique to a specific vehicle.
Its overly broad and general as stated
Ford specs adjustments referred to 5w 20 pcmo for belt driven cams . 5w 30 pcmo for chain driven cams per my friends in DearbornFord also changed the spec back to 5w30 on some of their engines calling for 5w20 to reduce warranty claims years ago. I read that here a few years back, it caused some interesting replies and debate, and some name calling as well.
Pure speculation on my part. I guess they had issues with timing chains in some applications running the 5W20 and bumped it up???? Either way it sounds like they might have been addressing warranty claims, or potential warranty claims??Ford specs adjustments referred to 5w 20 pcmo for belt driven cams . 5w 30 pcmo for chain driven cams per my friends in Dearborn
Ford never specd Full syn pcmo in their sump back then always , timing chains were an issue then . Most GF 6 will address this . Plus Dexos 1 gen 3 will be more up to date 'Pure speculation on my part. I guess they had issues with timing chains in some applications running the 5W20 and bumped it up???? Either way it sounds like they might have been addressing warranty claims, or potential warranty claims??
I agree, as always time will tell.Ford never specd Full syn pcmo in their sump back then always , timing chains were an issue then . Most GF 6 will address this . Plus Dexos 1 gen 3 will be more up to date '
Of course it does. A thinner oil film allows smaller particles to cause wear. It's not "0W" oils but the grade that causes this.while reading a link from this forum to machinery lubrication on the importance of BETTER oil filtration + NOT lkeeping todays MINI filters in TOO long it was noted the lesser oil film ow xxW20 oils is LESS protective as dirt particles are more likely the same size as the film + WEAR con occur for this reason!!!
Your first question is easy to answer. What benefit except greater fuel economy do you get with thinner oils? Manufacturers may have done so without the mandate, but increased fuel economy is the only benefit.But as a generality one can say yes, no?
Put it this way, if manufacturers weren't mandated to squeeze every last drop of fuel efficiency, would they be spec'ing thinner and thinner oils?
At the same time, thicker doesn't mean it will protect better. I'm sure you can't just put 20w50 in an engine designed for 0w20 and have it be better either.
