Yeah, that was it. So cool. I always valued his opinion (and Gary's) because they did real world analysis. Gary tested thin oils on his own Jeep and BGN tore down his own engines to determine what happened.
There would undoubtedly be a difference in the UOA on an engine with a sudden catastrophic failure in it and an engine slowly wearing. We just don´t know enough about those failures to know how much material wound up in the oil that was sampled. I don´t think it really adds much relevance to this discussion. But that´s just my humble opinion.
Ok but that 50s 5.2L V8 had like.....200hp (or even less)....Did 20W20 Mineral oil damage my dad's 1954 Buick with it's 322 cu. in. V8?
No.
It wasn't catastrophic in the sense that it tossed a rod. He had significant bearing wear, yet no evidence of that in his UOA's because the particles being shed were too large to be picked up by it. I'd call it reasonably rapid wear perhaps?
He had a UOA from his engine that was perfectly normal, yet it had no bearings left in it, IIRC.
It might still be running if he ran 5W30 in it.@BlakeB nailed it. So the correction is: If it wasn´t for start-up wear, they´d make it the equivalent of around the moon and back, probably 3 times or more before wearing out.
To the original question, regarding the Pentastar tear-down after it finally failed after 625k miles: It ran primarily on Valvoline 5w20. I´m sure that it would have made it to 626k miles if he had run a thicker oil, so the answer is yes, thinner oil causes more wear.![]()
It might still be running if he ran 5W30 in it.![]()
or W40It might still be running if he ran 5W30 in it.![]()
And by that description right there, regarding the size of particles, it is unrelated to this discussion and also does nothing to discredit UOAs as they relate to the discussion. Also, in my book, throwing a rod is a catastrophic failure. But again, opinions may vary. These are simply my own.
I'm saying it DID NOT toss a rod, that's why I said it wasn't catastrophic failure. He had some rather significant bearing wear upon tear down, which was done because he had observed reduced oil pressure. This was after having a UOA done which showed nothing abnormal.
Yes.
Picked up that bad habit from edyvw![]()
With the toyota, it wasnt that it was lugging the engine - infact it doesnt have much power (inline 2.5) at lower RPM to lug it. The issue was the shift logic was very very rough at low speeds and would do erratic unexpected downshifting. Like say it was rolling in 3rd gear at 15-20mph and you wanted to get on it for a bit more power, it would downshift to first instead of second which is not what the driver would expect in that situation according to the physical gas peddle.You got me thinking........ Over the years I've been in a few cars with 9 speed ZF automatic transmissions that actually lugged themselves. I'd be running something that offered better HTHS protection in those low revving engines than the 20 grade the mfg. called for to hopefully offer better bearing protection. Especially if a re-flash couldn't rectify the lousy shifting programmed into the transmission
If you really want a high HTHS oil then go up in grade, you'll get what you want by doing so. It's also why approvals are important since many European approvals require a minimum HTHS as part of the approval process. You want a higher HTHS oil? Then get one with an approval that requires the HTHS you are seeking.
Case in point: my gilfriend has a 2018 camry 2.5l that spec'd for 0w16. That transmission does absolutely everything in its power to keep the rev's down, it will even upshift by itself in manual mode. Lower rev's = sufficient low HTHS protection. It was so bad that toyota had to release a transmission software update to correct "jumpy" starts at low speeds.
You got me thinking........ Over the years I've been in a few cars with 9 speed ZF automatic transmissions that actually lugged themselves. I'd be running something that offered better HTHS protection in those low revving engines than the 20 grade the mfg. called for to hopefully offer better bearing protection. Especially if a re-flash couldn't rectify the lousy shifting programmed into the transmission.
or W40
