i wish I had some more data for you 2015_PSD,
Unfortunately I left the company as the Gen II was kicking off. I do know the engineering team was VERY nervous on the 0w-20 stuff and it was 100% for fuel economy. My personal opinion knowing the bearing surface area would not have gone up because of the cost I would go up a notch in weight. Not a lot of downside for the margin. Also, we are designing for 150-200K max, not 200k+ so that is always something to think about when OEM's make recommendations.
I would like to note there was this bearing coating they started using called iROX which was very impressive at the microscopic and testing level. It had to go on the front and back bearings to pass Stop-Start because of wear and was very expensive. They likely added that to the rest of bearings to make them work but I don't know for sure, I will have to ask. Regardless, the bearing surface area did not likely increase so from a basic physics point of view your hydrodynamic response to "filling it with water" as we called it will not go in a safer direction at lower rpm.
