Originally Posted By: rg200amp
We must keep in mind that Asus has been producing this router for, in realm of technology, a fairly long time. The N66 and the AC66 are essentially the same router. If the build methods that allow for heat production caused any issues, Asus has had plenty of time and user trial to rectify an issue.
I know, but they never did with the WL-500W/WL-500G family though
Quote:
Since everyone states the router runs warm and no issues have ever come up and Asus has not changed the building methods to reduce heat generation, one can safely assume that their are no foreseeable concerns. No issues found thus no issues to be fixed.
Just because a tech product runs warm does not automatically equate shorter life expectancy.
I know you, both as a IT professional as well as computer guru, like hardware running as cool as possible, but the amount of heat my router puts off, as well as the vast majority of the Asus 66 line I would imagine, is trivial at best when considering the thresholds of it's hardware's heat allowances.
Warm and hot are two different things though, warm isn't an issue. How warm is yours running currently? Does it align with Nick's observations or QP's?
For reference:
QP
Not sure how much hotter the AC66 runs, but my N66U on Tomato only feels
warm to the touch when propped on its stand. I wouldn't call it hot.
The stock Asus firmware has a temperature display. What temps are you seeing when you have it mounted sideways vs. the normal way on stand?
vs
Nick:
Originally Posted By: Nick R
When mounted on it's stand, The antenna connectors, and any metal on the back, feels hot, hot enough to actually be painful. The top/middle/front of the unit is fine mostly, but the back of it and bottom get ridiculously hot.
I burned my finger on the antenna connector once.
Those appear to be pretty different observations!
QP's device sounds normal. Nick's sounds "too hot" per my criteria.
I am on my MacBook, my downstairs TV is playing Netflix, and there is one iPad in use in the house now.
The router is just warm. The antenna metal screw on mounts are also just warm.
If I run every wireless device at once, I would assume the router may get warmer/hot. But I have not seen, heard, or read of any issues from that. So what is "too hot"???
One's perception of "too hot" and the hardware's tolerances of "too hot" are two different concepts on the table here.
Nick is more than likely running a lot more data through his network than the majority of wifi users. So it would stand to reason his would be hotter.
On the flip side however, it's people like Nick, the content/data heavy users, that are buying and using the $200 routers like the Asus 66.
Considering that the heaver users are the ones really putting this router to use, the lack of issues reported are one aspect that drew me to this router.
Believe me, I would of wanted nothing else to spend the same $200 on an Apple Airport Extreme. You know me!
After doing my research of the hardware, specs, reviews, features, range, ect. . . Hands Down the Asus is a solid router. So solid, it swayed me from my beloved Apple. That aint no easy feat!!! lol
