why use synthetic when Dino is so good
Central Iowa
Originally Posted By: cb_13
The carbureted straight 6 is dead and not coming back. Get over it!
just too bad one of the OEM's doesn't do a turbo straight 6 gasser for use in full size pickups. They sure have the compartment space to do that.. Inline 6's generally have great reliability. Freshen up the design and slap a turbo on it, and I would bet it would be a pretty good motor with fantastic low end torque. Simpler and probably less costly to build in full production. Though the length would be longer than a V motor, the overall real estate that the motor would consume under the hood would be less. A single turbo would suffice instead of having to do two of them like on many V motors.
Clovis, CA
Originally Posted By: NO2
1. Cold weather starts: 0w-20 starts easily at -35F to -40F. If you live in the far north that is a concern. Dino 5w-20 does not.
What part of the world gets down to -35F to -40F ? Are there people living there ? shocked
Australia
I think the point is if the oil flows at this temperature, then temperatures where most people live (where it regularly gets to 0F in the winter) will mean the oil protects very well at startup.
Maple Syrup Land
North of your border, laugh Canada
WA
Originally Posted By: ram_man
If you guys were going to switch to a conventional oil which would it be ? Which does best di engines? And if you were going to stay with synthetic and not do Mobil products what would be on your short list? Any oil these focuses seem to prefer?
PYB 5W30
Houston, TX
If you guys were going to switch to a conventional oil which would it be?
MS5K; pretty well proven in these parts.
If not M1 for synthetic, then SOPUS products, followed by BP products.
Missouri
I'm a Pennzoil fan. It's always given me good results. However the results of your UOA's with MS5K were extremely impressive. I would not hesitate to use it in any application that it met the specification for. So I would say PYB or MS5K as top conventional choices.
Missouri
A GTDI straight six in a half ton truck is something I would love to see!
Regina, Saskatchewan, Canada
Yes, Merk, I do, and I do go to work in that weather. What's worse, I make my staff go to work in such weather. wink
Kendall, FL
You you you...heathen. wink
Saskatoon canada
For me cost per mile is lower with on sale bought syns than on sale conventional oil. On sale jugs can be had for 30 bucks or less. I'd need to find conventionals for under 15 bucks a jug to make the cost equal or lesser. And less maintenance is nice too.
Washington
I also drive a 2014 Ford Focus. I'm not going to use anything worse than the SynBlend factory fill, and I'm happy to spend an extra $7/fill for Mobil1 since I probably spend ~$7k/year to own and operate the car.
Clovis, CA
Those temperatures would trigger a statewide emergency here in California. grin2
Hawaii, USA
Either is fine, go with what you know and like. My 1993 Toyota Hilux 4x4 pickup was born and raised on Amsoil and after it reached 100,000 miles, Mobil 1 High Mileage. WHen I overhauled the engine last year, the valves, pistons, crankshaft, etc. was clean. My mechanic friends said the same and asked what was the mileage and year. They couldn't believe their eyes.
