Soichiro Honda believed the perfect motorcycle engine is the V4... why
because if you are an engineer the V4 sports more advantages than an
I4... based on these physical facts...
1) Cube-like crankcase are inherently more rigid than the longer,
beam-like case of an I4 engine.
2)Long I4 crankshaft weights more than an V4...
3)Short V4 crankshaft has less distance to travel and thus takes
less physical effort to change direction than I4...
4) 90º V4 has perfect primary balance, a great improvement over
the buzzy, second-order vibration of an I4...
5)A V4 has less internal crank bearing friction and able to spin up
faster and deliver more rear wheel HP...
6) A narrow V4 affords up to a 35% reduction in aerodynamic drag over
the wide I4...
The disadvantages of a V-4 are mostly down to build costs. Two
cylinder heads, two sets of cams, two pairs of cylinders, two cam
drives and a more intricate cooling system...
