Originally Posted By: fdcg27
Are you letting the hot air out?
That is, do you have adequate ventilation in the roof to evacutate hot air from the loft space?
We had a new roof put on last year, and I decided to have ridge vents put in.
It has made an enormous difference.
It is ninety something here today, and the house is pretty comfortable.
If you don't have sufficient ventilation for really hot weather, add some.
It will really help.
I totally agree with fdcg27. A continous ridge vent is a major first start. Being in a condo-townhouse, however, I question whether one is installed? Do you at least have box vents installed on the backside of your roof? You want one or the other, i.e., box vents or the ridge vent, not both.
I have the same issue in my two-story, 2300 square foot home. It has a ridge vent and a Carrier Infinity system that is only four years old. Yet the upstairs rooms are at least six+ degrees warmer than the first floor, and nowhere near as cool as the walkout basement area.
I've researched this issue in-depth the past month. I've learned that it is quite normal for two-story homes to have a temperature variance of five to seven degrees between the first and second floors. Piling on more insulation in the attic beyond "normal" insulating recommendations will do little good.
I've settled on 38" tower fans in the upstairs area and ensuring the HVAC system has been checked and is performing at a peak level.
Friends in the "hotter" regions of the U.S. have multi-zoned areas for HVAC and the requisite thermostats to match. It's almost a mandatory requirement for survival in Memphis and much further southwest.
I'd recommend the model "2-120" air conditioner. That's 2 windows down on your 'Vette at 130 kph! Cool!
