Originally Posted By: ARCOgraphite
I would absolutely NOT run a 0w unless you are doing a lot of sub zero starts, It will do nothing for you and work against you v. warmer clime winter multigrades. (rated)
This comes up so often that I think it needs to be addressed. This just isn't true. A 0W oil is closer to operating temperature at any ambient temps, not just sub zero. At sub zero, MRV spec starts to become more important anyway. There's an advantage at running on oil that is a) closer to the correct viscosity at start-up and b)gets up to operating temps more quickly, regardless of the ambients temps.
Sure a 0W or 5W oil may have a higher percentage of VI's and higher burn-off under laboratory conditions, but this disregards the way most people drive. If you're consistently running your car for more than 20 minutes every time you turn it over, and you're using an inexpensive mineral-based oil, then the lower VI/NOAK oil
may have
some advantages. How long do you think the average trip is in an automobile?? Sure, if you're doing a ton of hwy miles and infrequent starts, there's potentially an advantage to a lower VI oil(depending on the VII improvers being used). That's not how most people drive.
The used oil analysis I've seen on modern 5W30's seem to indicate that any SM-rated oil is still suitable for use within a reasonable OCI.
Here's an interesting comparison of M1's 0W and 5W oils:
https://bobistheoilguy.com/forums/threads/mobil-1-0w-30-uoa-6-300-miles-ford-ranger-4-0.111352/
Lastly, I have to say I really haven't seen these sludged up engines (which you mentioned earlier) full of deposits on 0W30 and 5W30 oils.
