Yep when I was buying Havoline DS Pro 10-30 was always the one I was finding on sale.10w30 is NOT harder to find at all. I can find it at Wal Mart, Costco, Rural King, Tractor Supply and Autozone and Advance Auto Parts.
Nicely put.Plenty of good oil choices to protect the ENGINE. Too many are trying to protect everything BUT the engine.
What oil would best protect my image? I can go up to $18/qt if necessaryToo many are trying to protect everything BUT the engine.
If you have dilution 10w30 is still a much better choiceI would run 5W30 without worrying.
Especially if you are doing short OCIs, you will not run into the shearing issues.
Why is that? Dilution is mechanical with a low-viscosity fluid diluting a higher one. A 40-grade would be a "much better choice" in that regard.If you have dilution 10w30 is still a much better choice
10w30 is not harder to find as a viscosity, but sometimes there are less options for it. When I go to WalMart, AZ, Napa, etc, I always see 10w30, but it is usually only found from a couple brands, not all of them. It could just be for stocking/availability reasons, but I always find more options when looking for 5w30.10w30 is NOT harder to find at all. I can find it at Wal Mart, Costco, Rural King, Tractor Supply and Autozone and Advance Auto Parts.
That's because 5w-30 is the best viscosity.10w30 is not harder to find as a viscosity, but sometimes there are less options for it. When I go to WalMart, AZ, Napa, etc, I always see 10w30, but it is usually only found from a couple brands, not all of them. It could just be for stocking/availability reasons, but I always find more options when looking for 5w30.
Oil lasts about 1500 miles in a full synthetic 5w30 after which it sounds like a bunch of hammers in my CobaltWhy is that? Dilution is mechanical with a low-viscosity fluid diluting a higher one. A 40-grade would be a "much better choice" in that regard.
Hmm okay. And the turning to garbage is due to fuel dilution?Oil lasts about 1500 miles in a full synthetic 5w30 after which it sounds like a bunch of hammers in my Cobalt
Or about 3000-4000 on full synthetic 10w30
Have about 30,000 miles comparing each same situation 5w30 turns to garbage 10w30 lasts longer
I said dilution, the car manufacturers it’s own oil which is likely a combination of gas and antifreeze the rate and consistency varies greatly from very little (summer) to a lot (short trip’s winter )Hmm okay. And the turning to garbage is due to fuel dilution?
Depends on year/make/model/engine/location/intervalWhat oil would best protect my image? I can go up to $18/qt if necessary
Some history on how SAE J300 changed with time ... not "ol' wives tails".I haven't seen the historically difference with "W" rating other than clueless misinformation and ol' wives tails that have been spread forever.
Valvoline Advanced 10W30 is also a very good 10W30 synthetic oil with a HTHS of 3.5 .My favorite M1 EP 10W-30 is perfectly fine for Western WA. It's a very good oil. Jug says 20K miles! Should do fine for my 7500 miles oci. Wal-Mart has it every time I've been there and last week had "price reduction" tag ... I already had 2 jugs in the garage so I didn't buy more. Prices seems to be on their way down so there is no rush to buy more.
Another good option and oil that I use in my v8 is Valvoline EP 5W-30.
For my older cars I go to Kirkland or Havoline PRO-DS on sale at Wal-Mart.
It's 3.3, from what I've heard it's pretty much impossible for an oil will have an HTHS above 3.3 and still be able to meet the ILSAC fuel economy requirements.Valvoline Advanced 10W30 is also a very good 10W30 synthetic oil with a HTHS of 3.5 .
I don’t think there’s ever been an EJ engine that won’t run fine year round on a 0/5/10w40… some years I even leave the Motul 15w50 from summer in around the calendar, and either don’t drive it or give it 3-5 min warmups if temps are below zero.Subaru engines are notorious for failing, I wouldn't go down to a lower viscosity as it won't help any in avoiding failures. I would not consider mainstream 5W-30 adequate for these engines
There’s a 10w20 available that I’d personally use in my EJ25That's because 5w-30 is the best viscosity.
