Apologies if this is covered somewhere multiple times. I've tried phrasing my question basically and with terminology that may be used here on BITOG in the Search function, and I have failed terribly.
What I am wondering is, with the use of oil, how much does the ability to flow from cold start change? Is there an equation or algorithm for so many miles of use = so much change in CCS?
I am using 10W30 right now. Chose it because the NOACK nearly cut in half from 5W30, the HTHS is a little better, and the CCS change was from -22°F to -13°F. Southeast MO temps RARELY go negative, unless you factor in windchill and then the "feels like" can go sub-zero. This past week is a good example as we have seen temps get to 0°F briefly overnight and "feels like" temps have been as low as -16°F. My last two morning cold starts have been at ambient temps of 6° and 9° ("feels like" for both were sub-zero). The truck was a touch slow to fire-up and accompanied by higher-than-normal RPM's. The oil is 5 months old and has about 3.5K miles of use (a lot of it being trips ~25 miles of less). Truck is always parked outside, too.
I am assuming (from a few of the discussions that came up with some info) that with use, the specs of my oil have changed/degraded, but I couldn't really figure out if there was a way to determine or estimate by how much. With the stats I gave for my current OCI, could the CCS have been impacted enough to move from -13°F to 0°F or higher? Also, is CCS ambient temp or should I use the "feels like" temp as the standard? Lastly, is there a chance those two cold starts could have been dry or the filter in bypass for an extended period and caused damage to anything?
Wasn't really expecting a cold like this in SeMO this winter, but I think from now on I'll be using 5W30 or 0W30 for the winter months to avoid this being a concern again.
Thanks in advance for sharing your knowledge!
