As I do lack deeper understanding of both ASTM D5293 and ASTM D4684 I'd highly appreciate
some help.
Apparently ASTM D5293 is for CCS viscosity while ASTM D4684 is for MRV/low temp. pumping
viscosity. I came across a seemingly odd observation while comparing the datasheets of both
Ravenol REP 5W-30 and VMP 5W-30. To me they don't correlate the way I had expected. When
both are similar base oil composition (which is just an assumption), similar kinetic viscosity and
exact same pourpoint, shouldn't the oil with the lower CSS also exhibit the lower MRV? If it isn't
the case, should I conclude base oil compositions aren't the same? Different amount of VII?
Ravenol REP 5W-30:
www.ravenol.de
Ravenol VMP 5W-30:
www.ravenol.de
That said, Ravenol RUP 5W-40 acts as expected from a thicker version of REP (higher PP and KV40) .....
www.ravenol.de
..... while it's still lower CCS viscosity compared to VMP 5W-30 though.
Hope I made my little dilemma sufficiently clear. Again I'd highly appreciate administrable answers.
Thanks in advance!
for reference:
www.astm.org
www.astm.org
some help.
Ravenol REP 5W-30:
CCS Viscosity at -30 °C | 4301 | mPa*s | ASTM D5293 |
Low Temp. Pumping viscosity (MRV) at -35 °C | 14.870 | mPa*s | ASTM D4684 |
RAVENOL REP Racing Extra Performance SAE 5W-30
RAVENOL REP Racing Extra Performance SAE 5W-30 was developed together with Ralf Schumacher for motorsport and is ideally suited for car racing, even when s...
Ravenol VMP 5W-30:
CCS Viscosity at -30 °C | 4740 | mPa*s | ASTM D5293 |
Low Temp. Pumping viscosity (MRV) at -35 °C | 12.000 | mPa*s | ASTM D4684 |
RAVENOL VMP SAE 5W-30
RAVENOL VMP SAE 5W-30 is a PAO (Polyalphaolefin) based, fully synthetic low friction motor oil with especially USVO® and proven CleanSynto® technology for ...
CCS Viscosity at -30 °C | 4510 | mPa*s | ASTM D5293 |
Low Temp. Pumping viscosity (MRV) at -35 °C | 21.300 | mPa*s | ASTM D4684 |
RAVENOL RUP Racing Ultra Performance SAE 5W-40
RAVENOL RUP Racing Ultra Performance SAE 5W-40 was developed together with Ralf Schumacher for motorsport and is ideally suited for car racing, even when s...
Thanks in advance!
for reference:
Standard Test Method for Apparent Viscosity of Engine Oils and Base Stocks Between –10 °C and –35 °C Using Cold-Cranking Simulator
Significance and Use 5.1 The CCS apparent viscosity of automotive engine oils correlates with low temperature engine cranking. CCS apparent viscosity is not suitable for predicting low temperature flow to the engine oil pump and oil distribution system. E
Standard Test Method for Determination of Yield Stress and Apparent Viscosity of Engine Oils at Low Temperature
Significance and Use 5.1 When an engine oil is cooled, the rate and duration of cooling can affect its yield stress and viscosity. In this laboratory test, a fresh engine oil is slowly cooled through a temperature range where wax crystallization is known
