Hi,
I have been told on this forum not to look only at the static viscosities to determine if the oil runs better at cold starts but more at the pumpability of the oil (dynamic viscositity) which, from what I undertsood, is demonstrated with the Cold Cranking Start (CCS) and Mini Rotary Viscometer (MRV) values.
My problem is I have a hard time interpreting this value, therefore I need some help.
For the CCS value, I read on the Amsoil website that for a determined viscosity, the oil has to stay below a defined value to be called 5w for example. In my understanding, that means that a lower value means a better oil for cold starts: Am I right?
Unfortenately, I couldn't find any information on the MRV value, so is it the same as the CCS one? The lower the better.
Last point to clarify my mind: Comparing two oils trying to find which one is better at cold starts (assuming that the "the lower the better" rule applies to both values), if one has a lower CCS value than the other but the higher MRV value, which one of the values is more important to make the choice?
On this thread, I am only talking about the cold start characteristics of the oil, not the quality of the oil concerning engine wear, TBN retention, additive package, etc...
Thanks for your inputs.
